One of the largest benefits you will see when using SOLIDWORKS CAM is the time savings realized when using a system that is fully integrated with your CAD software.
With stand-alone CAM systems, the CAD files require translation into the CAM system. There are often translation errors or missing data when pulling your part model into a separate CAM system. Sometimes the version of the CAD file is not the same as the version that the CAM system is expecting to see, which also leads to translation errors. Because of the time required to “clean up” the part file when transferring it from a CAD system to a CAM system, programmers will often end up creating the part from scratch in the CAM system instead. If any changes or revisions are made to the part after the initial programming, the separate CAM file has to be updated or sometimes completely re-programmed. Keeping the CAD file, CAM file and G-code file all current can be challenging and time consuming.
With SOLIDWORKS CAM, you have a fully integrated CAD/CAM system, which means all the CAD data and CAM data are stored in a single file.  You no longer need to spend time maintaining separate CAD and CAM part files. Translation errors are eliminated and when changes are made to the CAD design, they are automatically reflected in the CAM programming. This saves a lot of programming time!
