Manufacturing of critical features with tight tolerances requires resetting the coordinate system. Probing operations are used to reset
toolpath coordinates to enable the most precise manufacturing capable by the machine for that application. Probing is now included in CAMWorks saving time in your toolpath generation setup versus manually adding these operations after post processing. Part setting of large and complex components, high volume or high precision equipment requires high precision manufacturing to achieve the desired performance. Components have many critical features with precise tolerances.
To meet these requirements, CAMWorks 2020 introduces Probing Operations. It’s easy to create a new probing operation and associate it to an existing setup. Choose the desired probe from your tool-crib, and select the previously machined surfaces to create new coordinate references for the subsequent machining operations. Like all CAM operations, it’s easy to move the probing operation in the tree, prior to machining features. CAMWorks 2020 makes it fast and easy to create your most complex manufacturing operations.
![]() Automatic | ![]() Web / Boss | ![]() |
![]() 3 Point Boss | ![]() Bore | ![]() 3 Point Bore |
