Selecting a CAD/CAM System for Manufacturing Transformation
Affordable integrated CADCAM for small machine shops
June 13, 2025
Automating New Product Development for a Sustainable Future
June 1, 2026
When selecting or reselecting a CAD/CAM system, each company must determine which solution best meets their specific needs and supports long-term growth.
Whether you are a manufacturer with in house production or a service provider operating in a global, cloud based environment, the right CAM software directly impacts productivity, quality, and time to market. This article provides a neutral assessment of key factors to consider when evaluating a new CAD/CAM system during digital transformation.
Why CAD/CAM System Selection Matters in Manufacturing Transformation
Selecting a computer aided design and manufacturing (CAD/CAM) system is not simply a technical upgrade. It is a foundational step that influences workflows across design, engineering, and production.
Modern manufacturing demands:
  • Faster new product development (NPD)
  • Better design to manufacturing connectivity
  • Automation and standardization
  • Scalable, future ready technologies
To meet these demands, organizations must move beyond legacy systems and evaluate solutions based on where the business is headed—not just where it is today.
The Role of Integrated CAD/CAM Software
A key advantage for modern manufacturing is seamless CAD/CAM integration. True integration means CAD and CAM operate within the same system and the same CAD file, providing full associativity between design geometry and manufacturing data.
Benefits of fully integrated CAD/CAM include:
  • Automatic update of toolpaths when designs change
  • Elimination of error prone data exchange
  • Improved collaboration between design and manufacturing teams
  • Faster turnarounds for design revisions and variants
Older CAM systems often rely on disconnected workflows, which slows down transformation efforts and introduces unnecessary risk.
Performing a Holistic CAM Needs Analysis
An effective CAM system evaluation starts with a comprehensive needs analysis. This assessment should cover all manufacturing processes—not only milling and turning, but also wire EDM, laser cutting, and multi axis machining.
Key considerations include:
  • Production technologies and machine types
  • Materials and machining strategies
  • Current and future automation requirements
  • Standardization across the shop floor
A common pitfall in CAM reselection is subjective comparison based on familiar workflows. A neutral evaluation requires openness to new manufacturing approaches enabled by modern CAM technology.
Manufacturing Transformation Requires New Perspectives
Transformation implies change. However, many CAM evaluations focus narrowly on current cycle times or legacy programming methods—often overlooking broader opportunities for efficiency.
Modern CAM solutions leverage knowledge based machining and automation to significantly reduce programming effort while improving consistency and quality.
CAMWorks from HCL Software is an example of a modern CAM system designed to support manufacturing transformation. Fully integrated with SOLIDWORKS® and Solid Edge®, CAMWorks uses intelligent automation and feature based machining to dramatically reduce CNC programming time and maintain tight associativity between CAD and CAM.
Ignoring such advancements due to familiarity with older systems can limit innovation and slow transformation.
Common Assumptions That Limit CAM System Selection
During CAM reselection, several assumptions can unintentionally restrict progress:
“The new CAM system must do everything better than the old one”
No system is perfect. Expecting a new CAM solution to outperform every function of a legacy system can eliminate viable, forward looking options.
“Our current CAM system is the only one that meets our needs”
This belief often reflects habit rather than necessity and can prevent organizations from adopting automation and standardization.
“Our employees are satisfied with the existing CAM software”
User satisfaction is important—but it should not be the only metric. System evaluations must also consider efficiency across design changes, part variants, recurring components, and long term maintainability.
Measuring Real CNC Programming Efficiency
Modern CAM software introduces automation that reshapes how CNC programming is done.
Capabilities such as:
  • Automatic feature recognition (AFR)
  • Tolerance based machining
  • Preferred tooling libraries
  • Material driven feeds and speeds
These tools help accelerate programming, reduce variability, and improve quality.
With CAMWorks, best practices and tribal knowledge can be stored in the Technology Database (TechDB™), allowing consistent reuse across teams and programs. Evaluating CAM efficiency through this broader lens reveals long term productivity gains that are often missed in short term comparisons.
Ensuring Your CAM System Is Future Proof
Manufacturing transformation doesn’t end after implementation. CAM vendors and technologies continue to evolve, making future proofing an essential part of system selection.
When evaluating CAM software, consider:
  • Frequency of software updates
  • Depth of technical support
  • Vendor stability and roadmap
  • Integration with complementary tools
CAMWorks, developed by HCL Software, continues to evolve with advanced CAD/CAM capabilities such as full CAD integration, tolerance based machining, ShopFloor Tools, and automation.
HCLSoftware also offers DFMPro, a CAD integrated design for manufacturing solution that helps identify downstream issues early—reducing rework and shortening product development cycles.
Conclusion: A Balanced Approach to CAM System Transformation
Selecting a new integrated CAD/CAM system is a strategic decision that shapes your company’s manufacturing future. A neutral, holistic evaluation—covering people, processes, and long term goals—is essential for long term success.
By involving stakeholders, assessing total productivity impact, and remaining open to modern automation, organizations can position themselves for improved efficiency, higher quality, and sustained competitiveness.
To learn more about CAMWorks, visit www.camworks.com.
Author: Dieter Ottmann
Email ID: dieter.ottmann@hcl-software.com
