Leveraging CAD/CAM Software to Maximize Material and Minimize Waste
CAMWorks and 3DEXPERIENCE SOLIDWORKS: Seamless Manufacturing Integration for Smarter CNC Programming
August 28, 2026
How Manufacturing Automation is Transforming Sheet Metal and Woodworking Production
Material costs continue to rise, customer expectations keep getting higher, and manufacturers are constantly looking for ways to improve efficiency. In industries like sheet metal fabrication and woodworking manufacturing, every sheet of material and every minute on the shop floor matters.
That's why more manufacturers are turning to CAD/CAM software automation to streamline production. By automating critical processes like nesting and CNC programming, businesses can reduce waste, improve accuracy, shorten lead times, and boost overall profitability.
Let's take a closer look at how integrated CAD/CAM solutions are helping manufacturers get more from their materials, machines, and workforce.
CAD/CAM automation for sheet metal and woodworking production
Optimize Material Usage with Integrated CAD/CAM Nesting Software
Material utilization has a direct impact on profitability. Whether you're cutting sheet metal, plywood, MDF, or composite materials, inefficient layouts can quickly lead to unnecessary scrap and increased costs.
Modern nesting software, such as NESTINGWorks® from HCL Software, helps solve this challenge by automatically arranging parts for the most efficient use of material. As a fully integrated SOLIDWORKS® add-in, NESTINGWorks works directly within the CAD environment, eliminating the need to transfer files between separate systems.
Maximize Material Efficiency
NESTINGWorks uses advanced algorithms to analyze part geometry and automatically place parts in the most efficient configuration possible. By pulling data directly from the SOLIDWORKS model, it ensures accurate layouts while maximizing sheet utilization and minimizing waste.
The result:
  • Reduced material costs
  • Less scrap generated
  • Improved yield from every sheet
  • Greater profitability on every job
For manufacturers working with high-cost materials, even small improvements in nesting efficiency can generate substantial savings over time.
NESTINGWorks nesting layout in SOLIDWORKS maximizing sheet utilization
Adapt Quickly to Design Changes
Production schedules don't stop when designs change. Because NESTINGWorks is directly connected to the CAD model, any design updates are automatically reflected in the nesting layout.
This eliminates the need for manual revisions, helping manufacturers respond faster to customer requests and engineering changes while keeping projects on schedule.
Faster Workflows and Shorter Lead Times
One of the biggest advantages of an integrated CAD/CAM workflow is the elimination of repetitive manual tasks.
Instead of recreating layouts or re-entering data, manufacturers can move directly from design to production. Automated nesting and toolpath generation significantly reduce programming time and help accelerate the entire manufacturing process.
Benefits include:
  • Faster job preparation
  • Increased production capacity
  • Reduced engineering workload
  • Improved responsiveness to customer demands
In today's fast-moving manufacturing environment, those time savings can provide a significant competitive advantage.
Improve Accuracy and Consistency Across Production Runs
Manual nesting leaves room for mistakes. Incorrect part placement, inefficient layouts, or missed dimensions can lead to wasted material and costly rework.
Integrated CAD/CAM solutions eliminate many of these risks by using exact model data throughout the production process.
With NESTINGWorks, manufacturers can:
  • Create consistently optimized layouts
  • Reduce human error
  • Improve product quality
  • Minimize quality control issues
For industries such as aerospace, automotive, and medical device manufacturing, precision isn't just important, it's essential. Automated nesting helps ensure parts are produced accurately and consistently every time.
Support Sustainable Manufacturing Practices
Sustainability has become a growing priority for manufacturers across every industry. Fortunately, improving material utilization also supports environmental goals.
By reducing scrap and maximizing material efficiency, manufacturers can:
  • Lower raw material consumption
  • Reduce landfill waste
  • Improve resource utilization
  • Strengthen sustainability initiatives
With optimized nesting, businesses can improve both their bottom line and their environmental performance, creating benefits for customers, stakeholders, and future growth.
Integrated CAD/CAM software for CNC programming
The Power of Integrated CAD/CAM Software for CNC Programming
While nesting helps optimize material usage, CNC programming is what turns a design into a finished product.
An integrated CAD/CAM solution, such as CAMWorks®, connects engineering directly to manufacturing by automatically generating machine-ready toolpaths from CAD models.
The result is faster programming, greater accuracy, and more efficient production.
A Seamless Transition from Design to Production
Traditionally, manufacturers often had to transfer data between separate CAD and CAM systems, introducing opportunities for errors and delays.
With CAMWorks, the CAD model becomes the foundation for CNC programming, ensuring the latest design information is always used.
This streamlined workflow helps manufacturers:
  • Eliminate duplicate data entry
  • Reduce programming errors
  • Minimize revisions and rework
  • Accelerate production schedules
When deadlines are tight, reducing the gap between design and machining can have a major impact on productivity.
Generate More Accurate CNC Toolpaths
CAMWorks uses the exact geometry from the CAD model to automatically generate efficient machining strategies, cutting paths, feeds, and speeds.
Because the programming is directly driven by the model, manufacturers gain:
  • Improved machining precision
  • Consistent part quality
  • Reduced programming errors
  • Less scrap and rework
For precision-driven industries, automated toolpath generation helps ensure parts are manufactured exactly as designed.
CAMWorks CNC toolpaths generated from the CAD model
Reduce CNC Programming and Setup Time
One of the most valuable features of CAMWorks is the ability to capture and reuse proven manufacturing knowledge through its Technology Database (TechDB).
The TechDB allows manufacturers to standardize:
  • Tool selection
  • Cutting speeds
  • Feed rates
  • Machining strategies
  • Company best practices
Instead of recreating programming logic for every job, CAMWorks automatically applies established rules and preferences.
This helps manufacturers:
  • Program parts faster
  • Improve consistency
  • Reduce setup time
  • Increase machine utilization
For job shops and high-mix manufacturing environments, these efficiencies can significantly increase throughput.
Prevent Costly Errors with CNC Simulation
Before a program ever reaches the machine, CAMWorks allows users to simulate the machining process in a virtual environment.
Simulation helps identify potential issues such as:
  • Tool collisions
  • Inefficient toolpaths
  • Incorrect machining strategies
  • Excessive machine movement
By catching problems before production begins, manufacturers can reduce downtime, avoid machine damage, and improve overall efficiency.
The result is a smoother production process with fewer surprises on the shop floor.
CAMWorks machining simulation in a virtual environment
Greater Flexibility for Custom Manufacturing
Every project is different. Material types, part geometries, tolerances, and production requirements can vary significantly from one job to the next.
Integrated CAD/CAM systems provide the flexibility needed to adapt quickly while maintaining efficiency.
Whether machining simple components or complex multi-part assemblies, CAMWorks helps manufacturers:
  • Support a wide range of materials
  • Handle complex geometries
  • Adapt to design revisions
  • Simplify custom manufacturing projects
This flexibility enables manufacturers to remain agile in an increasingly competitive market.
Why Automation Matters for Sheet Metal and Wood Manufacturing
The benefits of automating nesting and CNC programming are hard to ignore.
By combining solutions like SOLIDWORKS®, NESTINGWorks®, and CAMWorks®, manufacturers can:
  • Reduce material waste
  • Improve material utilization
  • Increase machining accuracy
  • Minimize programming time
  • Reduce costly errors and rework
  • Support sustainability initiatives
  • Improve profitability
As manufacturers continue to face pressure to do more with less, CAD/CAM automation provides a practical path to greater efficiency and long-term competitiveness.
Whether your goal is to reduce costs, increase throughput, improve product quality, or support sustainable manufacturing practices, automating your nesting and CNC programming processes can help position your business for success.
Learn more about NESTINGWorks and CAMWorks:
🌐 www.camworks.com
