CAMWorks Mill-Turn (Live-C) Machining
CAMWorks Mill-Turn provides a solution for both milling and turning on the same machine tool. Allowing for increased productivity and flexibility
Reduce Part Handling
CAMWorks Mill-Turn provides a solution for both milling and turning on the same machine tool. Allowing for increased productivity and flexibility.
PrimeTurning™ from Sandvik Coromant
  • PrimeTurning™ is available in CAMWorks
  • Reduce cycle time for turning by 50% or more
  • Increase insert tool-life by 500% or more
  • Full Library of PrimeTurning™ tools and inserts are included in the TechDB
Probing for Mill-Turn Machines
  • Define probing tools with new parameters for probe shank and stylus
  • Automatic selection of standard probing cycle based on face/feature selection
  • Dynamic display of probing toolpath to avoid collisions and broken probes
  • Probe stock and set work offsets automatically
  • Support for standard probing cycles
Mill-Turn in SOLIDWORKS Assemblies
  • Full Mill-Turn Support in SOLIDWORKS assembly mode
  • Include custom chucks, fixtures, and other machine components for simulation and collision checking
  • Synchronize simultaneous milling and turning operations with multiple turrets and spindles
  • Simultaneously machine both sides of a part or unique parts in the main and sub-spindles
Continuous B Axis Turning
  • Reach undercuts using a single finishing tool
  • Multiple cutting strategies for flexibility
  • User definable limits for the B Axis tilting angle
  • Specify effective lead angle or tool normal angle
  • Holder clearance setting to avoid collisions
Benefits of Using CAMWorks Mill-Turn
  • Reduce Programming Time by 80% or more
  • Automate the CNC Programming Process
  • Standardize to Improve Quality
  • Dramatically Reduce Setup Time
Improve customization and setup time...
Request Demo!
Datta Enterprises: A CAMWorks Success Story
“We believe that we will be able to service our customers better through greater manufacturing accuracy afforded by the platform. We also expect to improve our business flexibility and take up more complex jobs. CAMWorks brings in greater predictability into a job, which is very important.” - Shailendra Bhosle, Datta Enterprises
Datta Enterprises is a high-end manufacturer of critical engine and structural components for aerospace companies, oil field operators, and high-speed packaging machines, Kolhapur-based Datta Enterprises builds customized parts for its clients.
Read the full Case Study...
