Multi Axis Milling | 4 / 5 Axis Milling
Uncompromising Flexibility for Machine Tools
With HCL CAMWorks Multiaxis Machining software, take advantage of 4/5 Axis machines for greater productivity and quality from your CNC Machine
Equipment Flexibility
With CAMWorks Multiaxis Machining software, take advantage of 4/5 Axis machines for greater productivity and quality from your CNC Machine.
CAMWorks Multiaxis Milling software for programming multi-axis CNC machines allows for a wide variety of uses and applications. It is useful for both shops and manufacturing facilities that require flexibility in their software and machine tools.
Multiple Multi-Axis modules for your requirements:*
- 3 Axis Mill with undercutting - For 3 axis machining requiring undercutting.
- 4 Axis Mill - For up to 4 axis simultaneous machining
- 5 Axis Mill - For up to 5 axis simultaneous machining
*All Multiaxis modules include 2.5 Axis Mill and 3 Axis Mill.
Machine Complex Parts
CAMWorks 4/5 Axis simultaneous machining programming software allows the user to create toolpaths across complex shapes that could not be machined on 3 Axis machines. This includes high-performance automotive port finishing, impellers, turbine blades, cutting tools, 5 Axis trimming, and undercut machining in mold and die making. CAMWorks 4 Axis simultaneous machining is designed for complex rotary applications such as camshafts, extrusion screws and blades.
Reduce Cycle Time - Improve Surface Finish - Extend Tool Life
- Shorter cutting tools can be used since the tool can be tilted to adjust the angle between the cutter and the part. The increased rigidity of shorter tools allows you to take advantage of the high-speed options in CAMWorks to machine at higher speeds with no loss in accuracy. The result is better surface quality and reduced finishing time.
- Generating 5 Axis swarf toolpaths instead of traditional 3 Axis toolpaths can result in fewer cut passes and improved surface finish.
- By optimizing the angle between the tool and the surface, it is possible to achieve a constant chip load and a high feedrate at the contact point. The result is improved surface finish and extended tool life.
- Parts that previously required multiple setups can be machined in a single setup with simultaneous control of the rotary axis. In addition to saving time, this also cuts down on mistakes that might be made during multiple setups.
Improve customization and setup time...
Request Demo
The first SOLIDWORKS Certified Gold Product for CAM Software
CP-Carrillo: A CAMWorks Success Story
“CAMWorks was the only tool we found out there that could meet all our demands and their flexible approach on APIs really helped us move forward on this initiative to develop an Enterprise Business process that linked the order taking system with the design and manufacturing processes.” - Karl Ramm, CP-Carrillo
Since its founding in 1998, CP-Carrillo (Irvine, CA) has established itself as a leader in developing and manufacturing pistons for high-performance race vehicles and the aftermarket, as well as for vintage cars, motorcycles, and the marine and aerospace industries.
Read More
CAMWorks® best-in-class CNC programming solution enables users to program smarter and machine faster.
