Featured
Simplify Swiss Machining with HCL CAMWorks
Swiss CNC machines are ideal for producing small, high precision parts by performing multiple milling and turning operations simultaneously. HCL CAMWorks provides a user-friendly approach and powerful automation technologies to streamline and accelerate Swiss Machine programming in SOLIDWORKS. Watch this webinar to see the advanced CNC programming now available for Swiss Machining.
  • Learn how full integration in SOLIDWORKS saves times with Swiss Machining
  • Watch a demonstration of synchronization and simulation options available with Machine Aware Programming
  • See CAMWorks’ innovative segmentation manager for long parts
  • View efficient programming tools such as folders for data management and synchronized display of NC code
VIEW RECORDING
SOLIDWORKS CAM and Beyond - Expanding Your CAM Programming Capabilities
Knowing where to find the right CAM programming functionality is essential for manufacturers to be successful and remain competitive. This webinar provides information about the SOLIDWORKS CAM program included with every seat of SOLIDWORKS (versions 2018 and later, currently on subscription). It also includes details on where to access additional CAM options for functionality, such as 4-axis & 5-axis milling, mill/turn, wire EDM and more!
VIEW RECORDING
How to Reduce Machining Cycle Time and Increase Tool Life
Utilizing the latest machining processes is important for shops to remain competitive and profitable. Watch this webinar to see revolutionary technologies and toolpath generation that reduce machining cycle time and increase tool life.
  • Gain an understanding of how the latest toolpath technologies provide optimal material removal rates for both mills and lathes
  • Learn how you can increase your machine tool capacity
  • See a demonstration showing the machining results achieved by implementing these advanced toolpaths
VIEW RECORDING
Save Time and Money by Nesting SOLIDWORKS Parts and Assemblies
NESTINGWorks saves money by optimizing material usage and reducing waste – whether it is sheet metal for fabrication, woodworking, or soft goods. It automatically flattens parts and includes several advanced options to save you time in CNC programming. NESTINGWorks is a SOLIDWORKS add-in that works in combination with SOLIDWORKS CAM Pro and CAMWorks. Watch this webinar to learn about NESTINGWorks functionality.
  • See how NESTINGWorks uses full associativity with SOLIDWORKS and automatically nests SOLIDWORKS parts, assemblies, and folders of parts
  • Learn how NESTINGWorks provides true shape nesting, part-in-part nesting, user-specified grain direction, and layouts for parts with varied thickness
  • Watch a demonstration to see how NESTINGWorks produces the maximum number of parts from a single piece of raw material in a matter of minutes
  • Increase your productivity by saving time and money with NESTINGWorks!
VIEW RECORDING
5 Reasons why you should switch to integrated CAM
  • Have you ever scrapped a part because the wrong version was machined?
  • Would you like to accelerate your tool and fixture design?
  • Are you interested in automating your manufacturing processes?
This webinar shows how integrated CAD/CAM with SOLIDWORKS and CAMWorks can help you grow your business.
VIEW RECORDING
Improving CAM Throughput without Disrupting Production
There are several CAD/CAM software add-ins and add-ons that can be implemented into existing processes to automate manufacturing and save time. This webinar provides information on true G-code simulation, improving communication between CNC programmers and machinists on the shop floor, and nesting for SOLIDWORKS parts and assemblies.
VIEW RECORDING
Modernize Your Machine Shop with CAM Automation
In this webinar, hear how TECMA – one of the industry-leading companies specializing in high-temperature metals and custom machining transitioned their production and expanded their business with CAM automation.
VIEW RECORDING
Combatting the workforce shortage with CAM automation
Skilled manufacturing workers are difficult to find and hire.Through this webinar know how CAM automation increases productivity with your current workforce.
VIEW RECORDING
Turning reinvented: Sandvik Coromant’s PrimeTurning™ in HCL CAMWorks
Sandvik Coromant’s PrimeTurning™, available with HCL CAMWorks, achieves a high material removal rate - while reducing cycle time by 50% or more and increasing tool life by 500% or more, when compared to conventional turning.
VIEW RECORDING
Automate Mill-Turn Programming Using Integrated CAD/CAM
See how the latest integrated CAD/CAM technology automates the CNC programming process for Mill-Turn Machines. With integrated CAD/CAM, programming and setup time for complex multi-tasking machines reduces from hours to minutes. This webinar includes information on synchronizing simultaneous milling and turning operations with multiple turrets and spindles, simultaneously machining parts in both the main and subspindles, and creating probing operations.
VIEW RECORDING
SOLIDWORKS® CAM and CAMWorks - Leveraging MBD for Smart Manufacturing
SOLIDWORKS MBD improves designs by creating a smart digital twin to help reduce costs and make parts easier to manufacture and inspect. SOLIDWORKS CAM includes Tolerance Based Machining (TBM). Learn how MBD and TBM can be used to automate the manufacturing process.
VIEW RECORDING
SOLIDWORKS® CAM for Designers - A Path to Better Designs
Use SOLIDWORKS CAM to improve design, reduce cost, and make parts easier to manufacture. SOLIDWORKS CAM Standard is the CAM system included in every seat of SOLIDWORKS (versions 2018 and later currently on subscription). Learn how to automate the CNC programming process and improve your designs for manufacturing.
VIEW RECORDING
CAMWorks for Solid Edge
CAMWorks is the only fully embedded, feature-based CNC programming system for Solid Edge. See how CAMWorks full integration with Solid Edge will streamline your programming and accelerate your machining, with feature-based and knowledge-based machining, powerful associativity and automation capabilities.
VIEW RECORDING
Mastering CAM Integration for SOLIDWORKS
VIEW RECORDING
